Taskbar right click 'Share to Teams' does not work
When I am in a Teams meeting I should be able to share a desktop window with others in the meeting from the item on the taskbar. When using Start11 this option appears in the right click menu but does nothing.
1,304 views 7 replies
Sorry to hear you are having issues. Need to know more on your issue.
  1. Windows 10 or 11? Also need its full version and OS Build number. Please use Winver.exe.
  3. Teams version numbers.
I'm on Windows 11 24H2 and Start 11 v2.53 and Microsoft Teams version 25163.3607.3759.8168
thanks Mark
We shouldn't be having any impact on that as that's not a menu we are responsible for showing, that's all the OS.
Do you have anything else installed which might impact the taskbar or explorer?
Also do you have enhanced taskbar enabled and where is your taskbar positioned?
Quoting Neil, reply 4
End of Neil's quote
DisplayFusion, for example.
Yes, I do have the enhanced taskbar enabled but it is aligned to the bottom of the screen as normal and not customised further.
Mark
Things I would check
1) If you reboot does the problem continue?
2) If you disable the enhanced taskbar does the problem continue?
