Fix CursorFx click effects doesn't work
Some cursors when you click are supposed to change(slightly usually). Instead nothings happens, they remain the same. This is true for every cursor/theme. For example the hand cursor. You can test with every cursor thats supposed to change when you click. Even the default ones don't work on this regard.
21,255 views 16 replies
Please tell us what version your OS is, and which version of Cursorfx you're using.
Also, please post a video (youtube) of the problem, if you can.
I just downloaded CursorFx from you site. As simple at that. You can check it yourselves and see it doesn't work. The version is 4.03
My OS doesn't matter because its not working for everyone, but its Windows 10 Pro Version 22H2 OS build 19045.3271
In your program you call it "pressed state". Basically pressed state doesn't work. That's what im saying. Does it work for you? I don't think so but check it.
Quoting FixClickEffects, reply 2
End of FixClickEffects's quote
It works just fine for me, actually. Which cursorfx skin did you try? Did you use one of the skins  included with Cfx?
I told you already that i used the hand. I also used BasicFx and Position. All of this are default with Cfx included. Especially on BasicFx its easy to test. When you click the black thing is supposed to move.
On the left side of the config window, did you choose any effects? Settings? Trails?
There's a pdf below, and Cursorfx guides under Cursorfx 4 (Google). I'll pm a Community Support Assistant. Maybe your installation borked.
https://www.stardock.com/products/cursorfx/help/cursorfx_guide_04-07-08.pdf
i did not choose effects settings trails. I just clicked on BasicFx for example and nothing else. If you edit a cursor/theme and click on "view pressed state" it will show how its supposed to change when you click. Well it does not do that. It remains the same. Everything else works perfectly if that matters.
Sorry to hear you are having issues. Yes, if I remember correctly, this is known issue, where the press state on Standard mouse don't show up. I have checked again, and it does not show. To be sure, I have forwarded your problem/question to Stardock Support Team for their assistance. Please keep an eye on this thread for any updates. We appreciate your feedback and patience.
This is an known issue and is logged with the development team   (Internal Ref: ODNT-841)
Paul Scroggins
Nothing to report yet on this one.
It's being so long i forgot about this. When will this issue be fixed? Internal Ref: ODNT-841 . Also the join date of my account is August 2023. Not 04/2025 . Lots of problems going on.
I don’t have any updates on this just yet.
For your other problem, please raise support ticket using the link below, use the "Ask a Question" option. Include all information details. Remember to record down the ticket number for future reference if needed. Do not raise multiple ticket, that will make your ticket back to the end of the line. Send once and wait. Ticket will be answer by the order they send in.
https://stardock.atlassian.net/servicedesk/customer/portal/4/group/14
New user here. I'm also experiencing the problem; is there any expected completion date on this fix? It's been a couple years...
Sorry, but, nothing new to report yet on this one.
Is there an earlier version of CursorFX that has a working version of this feature? I'd rather go back to an older version since it seems like this fix isn't planned
The only way you can have a prior version is if you saved your installer. Stardock has only CursorFx 4 available for download.
