Control-Escape Problem in Start11
Wrong Menu
Control Escape is opening the Windows menu rather than Start11 version.
I'm trying to map a mouse button to open the Start11 menu and can't map the Windows key. Is there a setting somewhere to fix this? Or is there a command line that opens the Start11 Start Menu?
Gordon
7,506 views 11 replies
Sorry to hear you are having issues. You on Start11 version no?
Try this, uninstall Start11, reboot immediately after uninstall finished (important). Download and reinstall V1.45 (non beta). Reboot again after install finished. Retest it and report back.
No change. Ctrl-Esc still opens the standard Start Menu.
I even deleted settings during the uninstall, no change.
Need to know your Windows 11 full version number. Use Winver.exe. Also, you on tablet mode?
Windows 11 - Version 22H2 Build 22631.1830
Not running in tablet mode.
Thanks.
Gordon
Look like you have an insider preview version. Do know that Stardock does not support Windows insider preview build. However, we appreciate your report.
Thanks for the report.
This is something we will keep an eye on as this beta build of Windows  becomes closer to release
Paul Scroggins
I have the same issue on a fresh install of Windows 11, ctrl-escape is bringing up the original start menu, not Start11.
How do I fix?
Windows 11 Pro - Version 22H2 Build 22621.1928. Not in Tablet mode.
Quoting dalponis, reply 9
How do I fix?
End of dalponis's quote
How do I fix?
The solution is to use the Win key to open the start menu.
The options in Start11 are for the Win key only and changes in the Windows 11 OS recently alter how we have to handle that key.
