Start11 Right click volume on taskbar with dual monitors opens the menu on second display (with fix)
As seen on the screenshot below, When right clicking the volume icon in the taskbar the context menu shows on the second display. After tearing my hair out for days and plenty of googling trying to work out a fix, I finally found it.  for whatever reason this behaviour is caused by Start11 taskbar enhancements. Setting "Let Start11 enhance the taskbar" to off and restarting explorer fixes the issue.
Before:
After:
3,441 views 3 replies
Sorry to hear you are having issues. I can not reproduce the issue on my Windows 11 system. Need to know more on your system. Need to know what is your full Windows version number. Use Winver.exe to get them. Also need to know Start11 version number.
You should try the Start11 1.45 Beta: https://forums.stardock.com/518875. Try this, uninstall Start11, reboot immediately after. Download and install Start11 V1.45 beta. Reboot and retest it. Report back.
