Sound and Network Right Click Options
Since I installed Start 11 I'm unable to select the options when I right click the network or sound icons in the system tray. The options when I right click the clock work fine, but if I try to select Open Volume Mixer or Sound Settings after right clicking on the sound icon, the menu just disappears. The same thing happens with Network and Internet Settings when I right click the network icon. I ended up having to format my drive (thank you Windows Toolbox debacle) and clean install Windows again. The icons worked fine until I installed Start 11, then the same problem started again. I assume I'm missing something here given I didn't see any other forum posts on the subject. Anyone have an idea?
1,632 views 3 replies
What is the full numbered version of Windows ? use winver.exe for that info ..
Version of Start11 ?
Thanks for the link to the other forum, I'm apparently incompetent at searching. I'll keep an eye out for the update.
AzDude - My build is 22000.613 (21H2)
