Fences blur problem on multi monitor setup
I have a problem with my 1080p and 4K screens. Depending on the layout in the display settings, blurring fences will only work on half my 4K monitor. If I place my 1080p monitor somewhere on the right of my 4K monitor, the problem does not happen. The thing is, my 1080p monitor is physically on the left of my 4K, so it's not a solution.
^ The right side is not blurred at all
^ The bottom is not blurred
^ It does not happen when the 1080p monitor is on the right half of the 4K monitor
9,432 views 3 replies
Sorry to hear you are having issues. But, I tested it on my setup but I don't see it on my system. Below a screenshot on my system. 4K and 1200p. Need more information on your system.
  1. Windows 7,8,10 or 11? And its full version numbers. Use Winver.exe for it.
  2. Fences version.
  3. Do you have Monitor Manager software installed? Such as for me its Dell Display manager and LG Screen manager. Sometimes they effect each other. Try disable those and test.
  4. Do you have Wallpaper Engine running?
Hi! Thanks for your help. I am using Windows 11, fences 4.0.0.3, I have no other display manager installed and no Wallpaper Engine.
Ok, those was taken from my Windows 10 rig, so it might be Windows 11 thing. Anyway, I have forward your problem/question to Stardock Support Team for their assistance. Please keep an eye on this thread for any updates. We appreciate your feedback and patience.
