Edge titlebar not skinning after Edge update
The Edge title bar isn't skinning after the new update. If I reboot my computer Edge is skinned. If I close Edge out and open it again I get Win 10 title bar. All settings are the same in Edge as they were before.
Edge Version 91.0.864.37 (Official build) (64-bit)
Curtains Version 1.18
Windows Version
Edition Windows 10 Pro
Version 21H1
OS build 19043.1023
Experience Windows Feature Experience Pack 120.2212.2020.0
8,804 views 8 replies
How are you relaunching edge after you close it?
The shortcut that was placed on the task bar. That's where I always launch it from.
Just a quick update my laptop is doing it too. So it's just not isolated to my desktop.
Sorry to hear you are having issues. Please check if you have turn "continue running backgroundapps when Edge is closed" option off.
Yup it's off.
Is the issue happen on all Curtains Style?
I fixed it. It was the top switch in the Edge settings. I turned off "Are you satisfied with startup boost?" and it worked. I don't know why that would effect it.
Thanks Guys
Awesome, glad it get solved. Thank you for reporting that.
