Right-click tray icon "Configure Multiplicity, does not work anymore
Yet, Right-click tray icon, Kvm Mode & Unload, do work?
Win 10, v 1909, b 1863.836
This is happening on a desktop and a laptop.
What I  have tried.
  • Uninstall, reboot, reinstall.
  • Used your file "Purge_MP.bat" to uninstall, reboot, reinstall.
No Joy.
Al Guevara
6,358 views 7 replies
Then something you have - on both PCs - is likely blocking it.
All that does is bring the MP UI up.  If you search \ click \ run 'Mutlipicity' from the Start menu, it should open the same thing up:
https://cdn.stardock.us/support/uploads/2020-05-21_13-48-54.mp4
Thanks Sean
You'd think 2 uninstalls would fix it ?
Is there a LOG I can look at that might give me clue?
Quoting AlvaroGuevara, reply 4
Thanks Sean
End of AlvaroGuevara's quote
None that would give an indication of what was causing it, no.
Are you able to open the UI as I did in the video?
Yes, but it be nice if it worked normally. Ive no security soft installed, I've reset the Win firewall, twice, Ive even ALLOWED EVERY stardock exe file to the firewall. Still no joy.
If you do a cleanboot, under a new Windows Admin account, does it still happen:
https://forums.stardock.com/486104/multiplicity-support-faq#cleanboot
If all cases fail, perhaps a purge \ reinstall is in order:
https://forums.stardock.com/486104/multiplicity-support-faq#reinstalling
