Fences translucent doesn't work properly with third party wallpaper called "Wallpaper Engine"
My background wallpaper
As you can see the translucent effect is showing the background that came with my razer laptop and not the moving background I'm using with Wallpaper Engine. I've tried finding a setting to fix this and nothing works. Also when selecting the setting for "Fences with round corners" shows the round but you can still see the frame of the fence so the corners are still squared but with the "translucent" window being round. FYI the translucent slider is all the way to the left.
11,472 views 3 replies
Glad you corrected the spelling. :-)
Hello dandan,
I believe there were few reported issue on incompatibilities between Fences and Wallpaper Engines. And I do think that Stardock Support already know about it. (Ref : https://forums.stardock.com/497595/get;3764240)
Would like to suggest Stardock Deskscape as alternative which should be 100% compatible with Fences. https://www.stardock.com/products/deskscapes/
Basj
