[Problems] Multiples problems found
OS :
Windows 7 Pro (latest updates) in French
Groupy version :
1.19
I have 2 problems with Groupy (tests with 1.19) :
1/ When saving folders, the program doesn't seem to to understand how to open them, showing instead the following message :
Here is a translation :
V:\test
[Content]
No program is associated with this file to perform this action. Install a program or, if you have already done so, create an association in the Default Programs Control Panel.
I tried to find out in a VM what's going on, and it seems that saving any folder with UAC disabled would make the folder restoration impossible.
Simply changing the parameter "RunElevated=1" to "RunElevated=0" seems to solve the problem, but I have to manually do it on every groupy file...
Is there a way to support the disabling of UAC?
2/ Restoring folders with Japanese, or Korean characters (and probably Chinese), simply doesn't work. Here a perfectly fine and working folder name  "分福茶釜" :
The target in the generated groupy file displays something like that :
Target="C:\????"
This makes restoration impossible :
Changing it manually to Target="C:\分福茶釜" doesn't work and throws another error :
Trying the same with completely Japanese system doesn't seem to work either, and throws both times the same error, except this time in Japanese obviously :
Target="C:\????"
Target="C:\分福茶釜"
Thanks for any help, I'd like to use the program :)
1,865 views 1 replies
