Basic Help With SkinStudio Required!!!!!
You probably have guessed I'm new to the community, I have been using WindowsBlinds for ages but I have only just got around to getting SkinStudio so I can (Attempt to) make my own skins.....
It seems to be going OK, despite the lack of ANY useful tutorial or help files > >
I am Having a problem with radio buttons, check boxes and system buttons, in that If I make my own images for them (bitmap of tga) they allways end up an odd grey colour
This is really starting to P me off, so any help wpuld be appreciated
Thankyou for taking the time to read this post
1,454 views 6 replies
Make sure translucency (not transparency) is disabled if you replace a tga with a bmp. A lot of the default tga's have translucency enabled but if it is enabled for bmp's you get this opaque image.
Hang in there Mikey, answers will be forthcomming from some expert wanting deperately to help you out.
Powered by SkinBrowser!
I have Tranlucency on...
I managed to get the system buttons to display propperly with a bit of fiddling..! But the check boxes/radio's are still weird
heres the code for em:
[Button.CheckBox]
LeftWidth=0
RightWidth=0
TopHeight=0
BottomHeight=0
PerPixel=1
Trans=1
Tile=0
TileTop=0
TileBottom=0
TileLeft=0
TileRight=0
[Button.Radio]
Tile=0
BottomHeight=0
LeftWidth=13
RightWidth=0
TopHeight=13
MouseOver=1
TileBottom=0
TileLeft=0
TileRight=0
TileTop=0
PerPixel=1
Alpha=255
Trans=1
Disable translucency (turn it off)
Mikey: You might want to report this on the newsgroups.
