How to Fix the Problem when Fences and Icons Will No Longer Move!
Hidden Feature Revealed
I had a severe problem when my Icons and Fences
seemed to be stuck and I could not move them!
I notice other people on the Forum have complained about this,
but no-one has come up with a Solution!
It really is a simple Solution and
it should be readily available and  clearly visible in the
Support Documentation.
Just Right Click on a Blank Area of the DeskTop
and Click on
'View'
Make sure that 'Lock Fences' is UnTicked!
Right Click Desktop > View
13,502 views 8 replies
It's so simple that it doesn't work!
This "solution" did not solve my stuck icons problem with Fences 2.13 on Windows 8.1.
OK, Now check in Fences settings to be sure that Lock Desktop isn't checked.
That option may not be available in 2.13. I am running the beta 3 version.
Please contact support so we can see what is happening.
https://esupport.stardock.com/index.php?/Tickets/Submit
I contacted support. For now the problem has not been solved.
Fences do not seem compatible with the latest version of windows (1607 anniversary update)...
