[Bug] Ship Designer Bug Parts not saving properly?
Hi there
(First time caller, long time listener!)
I'm having difficulty saving parts from the ship designer.  Sometimes only a part of the component saves.
For example:
I crack open the Terran transporter template and grab the central little cross thing (made of Terran Model 23 and 26) using CTRL LMB from the component list, adding parts left-to-right. I then hit the little save-grouped-parts button, and it appears in the Parts menu - although I usually get the blank-thumbnail bug too.
But anyway, thumbnail aside, when I click on the new part it only shows Terran Model 26, and the 4-mirrored Terran Model 23 little arm things in the shape of a cross are missing.
This happens pretty much everywhere, whether grabbing a group of components from an existing design, or building a ship from scratch. Some "bits" will always be missing from the saved component.
From what I can see I'm following the types of steps that for example Gauntlet uses in his Race Mod YouTube tutorials, but I can never get them to work.
Is this a bug or a Class I Operator Error?
15,881 views 3 replies
Yes, this is an exciting topic. I also encountered a problem when saving custom often I do not receive full sset - in the new custom part only half of the marked parts  remained :'(
Custom parts will not work properly if:
1) All parts are not connected to each other.
2) You use mirror commands.
3) A part is added to a custom part, which is connected to your entire new custom part ;)
1) No, I checked it out
3) No, I already know that it is not working  ^_^
2) Usually it does not affect the process of saving.
