Problems with system tray icons
Cannot choose system tray icons, or change from low res icons
Hi all,
I wonder if anyone can help.
Having tried the basic version, I have just bought ObjectDock as I really wanted system tray support. However, I can only show all the system tray icons, or none, as if I deselect “show all tray icons at all times” it does not allow me to choose which icons I would like displayed. The error I get is “retrieving of system tray icons failed. Please try later”.
Also, is it possible to replace system tray icons as they are really low quality.
Cheers
Sanj
:S
3,350 views 2 replies
Click and hold on the icon you want to change (l-click or right, I forget which) and you will get other options, like changing the image. Dig through the icons gallery on WC  to find higher quality replacements.   https://www.wincustomize.com/explore/icons
Thanks for this. That works (l-click hold).
Now, if I could just select to only have some icons rather than everything...
Regards
Sanj
