System Colors and Standby problem
Hi,
I'm using trial version of 8.0 with Windows 8. Everything is ok, but i have a problem. I'm changing system colors under Color tab. Then i'm putting my pc to standby mode, and after open it again, some of system colors will reset. You can see the difference at image below:
I can solve this problem with applying the theme again, but this does not solve the actual bug.
Thanks.
1,610 views 3 replies
Did you reboot after installing the trial version? This allows Windowblinds to recognize your system.
Yes, many times. But i'm gonna try to reboot after applying the theme. Maybe this will help, thanks.
Edit: Nope, that didn't work.
I suggest you send an email to support. Send only one though as additional emails will kick yours back to the end of the line.
