Need help with fences pro
 I have just installed fences pro for the first time after owning it for over a year. I am trying to get use to how fences pro works and the only negative thing I could say is about me, I just take a while to decide if I like something.
I can see how fences pro can be a great program, I use my desktop for all my shortcuts anyway. Fences makes the desktop look much more organized and I guess that is what Fences Pro is for.
One thing I wish I could change is the color of the titles for each fence.  Mine are white and with a light color or image for my desktop the titles just blend in. If I could change the color of the title bar it sure would make things easier for me.
If I am wrong and the title color can be changed please tell me how. if not maybe they can add that to future versions.
3,851 views 2 replies
Fences 2 allows for each Fence to have a unique color.
Right click on your desktop and select Configure Fences. Click on Appearance. On the right side just under the Saturation slider you will (or should) see Change label text color. That'll do it.
