Lower left hot corner problem.
Problem when returning to desktop. I click on windows 9 start screen link  on desktop start menu and I am taken to the start screen. After working in that environment I click on the lower left hot corner to return to the desktop and on return find the start menu is still open and have to click on the screen to close it. If however, I return to the desktop using the upper left hot corner the start menu is closed as it should be. Very annoying.
1,744 views 3 replies
Quoting pettitkj, reply 1
Sorry, should read Windows 8 start screen link
End of pettitkj's quote
If you check the control settings page in Start8, do you have it set that the bottom left corner when in a modern UI application opens the Start8 menu?
