Need help in importing/exporting mesh with 3ds max
Hi,
I'm having troubles in importing/exporting mesh file with 3ds Max.
- OS Windows 7 Ultimate 64bit/ATI RADEON HD 7470/4GB RAM.
- 3DS Max 2010 with soseplugin_v.2.0.8 Rebellion supported
- SOASE Rebellion 1.03
Importing: When I was importing binary mesh to 3ds max project, the 3d object loaded without mesh points.
Exporting: When I was exporting 3ds object with some mesh points, first, it showed message box "No nodes added to GameMesh processor", then i tried to select all, then exported, then i showed message box "No bones added as points".
I tried to follow this tutorial: https://forums.sinsofasolarempire.com/341022 only different point is 3ds max with rebellion plugin.
Can anyone help me with 3ds max and rebellion?
Please do not tell me to use SoftImage tool, i repeat, do not tell me to use that tool, that is my nightmare after set up that software in different version again and again and followed all tutorials i could find from google, and it stilled crashing in startup.
Thank you very much!
2,302 views 0 replies
