same problem as ticket : #BLH-165866
cannot install previously purchased window blinds version 4
dear forum,
I'm calm, cool, and relaxed. I'm not going to go off about how your making it hard to install an already purchased product (yes, version 4 window blinds. And no, it's fine, I don't need an upgrade. But thank you) on an older computer (ok, ancient, pentium 4, go ahead, laugh it up. It cost me exactly zero dollars, and works just fine which is exactly how much I have saved up from my not job I've not had for two years) because you want to sell me something else. I'm trying to run my purchase on almost the same system as when I purchased it. Again, laugh it up. Then send me a link to install my purchase. Thank you.
1,287 views 4 replies
curtbender, Stardock Support used to do that but stopped 12-18 months ago.
It's really unfortunate because my guess is that you didn't archive it... and SDC doesn't exist anymore.... so, I doubt it's gonna happen.
Hi.  There's nothing wrong with your account so you should be able to download and install WB4 from the store download page.  What is not working?
Nothing wrong with that, an excellent line.  I'm typing on one now.
Perhaps a link to the current download page will be helpful, things have changed a bit since Stardock Central.  Login here:
https://store.stardock.com/login.aspx?ReturnUrl=/myaccount/products
Jeez ... I haven't seen a Pentium 4 in ... wow ... a really long time but put it together with XP and you got a pretty neat system. Kudos to curtbender.
