Help with fixing several problems with old skin
https://www.wincustomize.com/explore/windowblinds/2363/
Hey!
I used a specific skin several years ago, with Windows XP, and now I would like to start to use it again, but it has several features
that does'nt work as they're supposed to in Windows Vista/7. First of all, if you go to a website, or a program installation that has
check boxes, you can't see them, which makes it pretty hard to use the skin. Then there's this issue: I've got the taskbar on the
right side of my monitor, and when the programs that are open are listed there first of all they start to far down the taskbar, there's
a quite big gap between the start-menu button, and the first program, which also is kind of a problem, and last there's a too big space
between the open-program buttons, now I wonder, is there any way that I can fix these problems myself ? I've got SkinStudio, and I
have tried to open the skin but I don't really know how to fix it, please help me.
SkinURL: https://www.wincustomize.com/explore/windowblinds/2363/
Best Regards
Henrik Andersson
2,366 views 8 replies
You're trying to use an XP skin on Win7. Most XP skins will not show correctly on Win7, dimensions of the start menu, frames and placement of text is very different. This isn't true of all XP skins but for most it is. I don't think Olympics has been updated for Win7 or not. Might want to PM treetog and ask him.
A little "bump" for the night crowd.
Seems like it would be an excellent topic for some knowledgeable people.
Yes, Fixing up a skin made for XP to work on 7/Vista is a Major thing, not just somethin someone can just "help" you with in a jiffy. :\
Yes I know it's built for XP. It has'nt been updated for win 7, and I have already contacted treetog, but he told me that he is'nt working with windowblinds anymore, so it would'nt be any updated version of Olympics, and that's why I was asking for anyone who could help me/point me in the right direction so I could fix it myself. I have no intentions what so ever of releasing a updated version, if I manage to fix the issues, if I don't get permission from treetog ofcourse. If he does'nt respond to my request, or if he denies me to release an updated version, I will only use it for myself, but I would really like to fix the issues and at least be able to use it for myself. That's the main goal.
Best Regards
Henrik Andersson
Sorry, did'nt see more than the first reply since I did'nt update the page before posting my reply, but I can understand what you are saying. But do you know if there's any guide or anything that might help me to fix all of my issues, or any one of them, at all ?
Tjena Henrik, -Det bästa sättet är att köpa Skinstudio och läsa en "tutorial" och att fråga oss här om det skiter sig. hoppas det hjälper dig.
Hia Henrik.
-The best solution is to buy Skinstudio, read the Tutorials and try to do it yourself, ask this helping community for advice when needed. :sun:
Hehe, okej, jag har prövat lite själv med skinstudio, dock inte läst någon tutorial, men givetvis så får jag ju göra det om det inte går att lösa på ett annat sätt... :)
