sound problem after patch
Hello, Is this game still being supported?  I have not heard back from Stardock in about a week with regards to my ticket for this game.  I installed the latest patch through gamestop impulse however it ended up corrupting the sound files.  I get different voices and randomized sounds when I play the game.  Comically, it's pretty funny to hear randomized sound files throughout the game ("this would be faster if I had wings when the intro movie plays)  but it really reduces the game immersion when the narrator and your demigod gives u all the wrong info.   Can anyone help with this sound problem?  I have already done a complete uninstall of the impulse and the game and a reinstall.
I tried checking the forum, but can't seem to fine a solution to this problem.
5,963 views 14 replies
Try this: http://forums.demigodthegame.com/369625/get;2450872[quote]
Quoting XaviorsFist, reply 9
I fixed it. In your demigod files under program files and stardock games there is something called dem_loc_update and if you run that it will fix it in seconds. All my sound was back to normal everything.
For my computer it was under C:\Program Files\Stardock Games\Demigod. It is an application type program and shouldn't be hidden at all.
End of XaviorsFist's quote
Make sure to run the dem_loc_update.exe as Administrator.
I don't have dem_loc_update.exe under the demigod folder.  I also did a search for it on my win 7 (64 bit) and can't find that file at all on my system.
I have tried to run demigod.exe as admin but nothing seems to work. Vanilla works fine if I uninstall and not upgrade to the patch.
Did you try doing a registry clean before the reinstall?
Yes I have completed a registry clean and defrag.
Quoting LordOlni, reply 2
End of LordOlni's quote
Which files and folders do you have in your Demigod root?
under C:\Program Files (x86)\Stardock Games\Demigod I have the following files and folders
bin
bindata
loc
movies
redist
sounds
dgdata.zip
eula.txt
readme.txt
uninsthelper.exe
the window's search could not find the file dem_loc_update.exe
I'm sorry,i have the exact same problem (sounds scrambled,already uninstalled and reinstalled,no dem_loc_update file).
Anyone has a solution?
Thank you and sorry for my bad english.
mail, [email protected]
Quoting lepalle, reply 8
Is there any other way to get technical support?
Btw,bump.
End of lepalle's quote
Seriously I e-mailed them twice and no one responded.  I guess everyone is too busy working on enchanted princess and decided to neglect other games.  This game has so much potential if it was only supported with regular updates such as LoL.  With the sound issue, it does prevent you from knowing what's going on in the game.  I wonder if steam players have this problem.  It would be wise for stardock to stop selling this game until they fix the sound issue.
Quoting LordOlni, reply 10
lol
can you copy files from someone who has steam account and game working well?
Its probably rare issu, maybe something with sound settings in  windows?
Is everything else working well?
Did u try choosing different sound output device? (windows sound setup?)
I have fixed the problem.
1. backup your savegames ("C:\Users\USERNAME\Documents\My Games\Gas Powered Games")
2. deinstall Demigod
3. reinstall normal (unpatched) version form original CD/DVD
4. backup the file "Forge.fev" in folder "C:\Program Files\Stardock Games\Demigod\Sounds" (Version 1.0 = 1.040 KB)
5. patch Demigod
6. backup the new file "Forge.fev" (Version 1.3 = 1.154 KB)
7. overwrite the file "Forge.fev" with 1.0 Version
8. recopy your savegames
9. start the game and have fun :)
P.S.
I have Windows Vista and a german Demigod Version.
Demon Assassine and Oculus have no Sounds
All steps go at your own risk, I assume no liability! ;)
Ich habe das Problem behoben.
1. sichere deine Spielstände ("C:\Users\USERNAME\Documents\My Games\Gas Powered Games")
2. deinstalliere Demigod
3. installiere die normale (ungepatchte) Version von Original CD/DVD
4. sichere die Datei "Forge.fev" im Order "C:\Program Files\Stardock Games\Demigod\Sounds" (Version 1.0 = 1.040 KB)
5. patche Demigod
6. sichere die neue Datei "Forge.fev" (Version 1.3 = 1.154 KB)
7. überschreibe die Datei "Forge.fev" mit Version 1.0
8. Kopiere deine Spielstände zurück
9. starte das Spiel und habe Spaß :)
P.S.
Ich habe Windows Vista und eine deutsche Demigod Version.
Demon Assassine und Oculus haben keine Sounds
Alle Schritte gehen auf eigene Verantwortung, ich übernehme keine Haftung!  ;)
Try to avoid installing from CD and patching (where the problem occurs), and instead download and install the game from Impulse. This is what worked for me recently.
