Problem with sys tray icons - help?
Hi,
I had this same problem about a year or two ago, and, had at that time found the solution here on the forums but for the life of me I cannot find it on here now. The problem: I applied a Windowsblind skin and just noticed that it had changed my system tray icons (ones next to the time) to look old and block like, like maybe a lower resolution maybe?
Does anyone know the fix for this? wished i would have wrote it down the last time i found it :/
EDITED: Just to say I am on Xp if that helps.
Any help is much appreciated - Thanks in advance :)
2,486 views 2 replies
Did you try to log out and then log back in?
Did you try rebooting?
DPI @ 96.
Control Panel /Display /Appearance /Advanced: alter the Caption Buttons selection in the Items drop down
menu that controls the size of the Notification Area (System Tray) icons.
