kona0197 kona0197
Problem with laptop starting up. Need some help...
Well I guess that's the last time I do a Craigslist deal. Any ideas on how to fix? Video tells the tale.
http://www.youtube.com/watch?v=IVdsuXGn4oQ
59,187 views 33 replies
Reply #26 Top
Doesn't look like corrosion. Could it be lock-tite? Or perhaps that battery's been compromised. The white maybe the electrolyte in the battery leaking out. Try using a small plastic or composite screwdriver and gently go under that clip. See if you can work it loose.
Reply #27 Top
http://www.techsupportforum.com/forums/f210/acer-aspire-7520-repeats-going-and-off-343165-2.html
Re: Acer Aspire 7520 repeats going and off.
I have been recently handed one of these laptops for repair and I can confirm that the fault that I have here is that upon pressing the power button the firstly the processor fan spins up and after a couple of seconds it stops. The power light goes out and then the cycle continues without the processor fan spinning up, the only way to stop this is by removal of the battery and external power.
I have located the problem and in this particular case it is a design fault. The NVidia GPU is not mounted well and requires removal, reballing and resoldering to the motherboard. This fault is exactly the same as the problem that was experienced with the XBox 360 and is a genuine manufacturing flaw.
The oven trick may work but please dont actually put the whole laptop in the oven, you may end up with quite a mess, totally strip down the laptop and only put the motherboard in the oven. Personally I would not recommend this technique as you may end up causing irrepairable damage to something that could be repaired in a very sensible and more relyable way.
This afternoon I am going to attempt to get Acer to resolve this issue as I can see that there are many forums concerning faults with this model of acer laptop that uses the NVidia GPU.
Reply #28 Top
According to that thread the only 'layman' solution is to cook the MB in an oven...it's a dry joint issue, it seems.
It'd be curious to know how many people tried and fried .... but seems several got it fixed....;p
Reply #29 Top
Well I will let someone else deal with "cooking" it. Saving up money to buy a new one while borrowing one from a family member for school. Thank you Jafo.
Reply #30 Top
Quoting Jafo, reply 28
End of Jafo's quote
Reply #31 Top
:w00t:
Reply #32 Top
I don't care what they say....Craigslist will always be about someone getting screwed.
Reply #33 Top
lol.
