Please help with Sysmetrix 3 crashing issue!!! *cross-post*
Sorry to repost, but i got 2 replies in general til i realised there was a whole help section where i should have posted. Re: sysmetrix 3. Downloaded Sys 3.0 and installed it. Had never used it before. Loaded P98 skin (it's great) and all works well until i right clicked by accident on the program. Crashed. Uninstalled, tried diff skins. Downloaded 2.xx for reference. 2.0 does not crash. But it does not have the weather thing, so I'd love if someone could help me clear it up.
System specs:
Inspiron 8100 1.2Ghz Tualatin
512 MB RAM
RADEON 9000 64MB
Windows XP Pro
It doesn't seem to matter what I do. Even right-clicking the icon in the system tray crashes it, hence I can't get into the config anymore. Only can do that on a fresh install. I think too after a fresh install it right-clicks fine until i get the weather, i get the weather just fine, then afterwards i try to right click and boom! crashout. It might be a bug in the program itself. Just wondered if anyone had has this happen and if so how they fixed it. Thanks for the help.
don 1 shott3r
1,588 views 2 replies
Make sure the METAR Code for your area's weather is correct and that you have given permission in your firewall (if you have one) for that port.
Powered by SkinBrowser!
I had some trouble with it to not too long ago. I ended up having to uninstall it then go search the registry and make sure all sysmetrix entries were gone. I then reinstalled it and it has worked find since. May not fix it but its worth a shot.
