Problem with minimized and then maximized programs from tray
menu isn't displaying right
I will take foobar2000 for example, but I noticed that this happens to other programs. I think all of them that have classic menus and are minimized to tray icon!
Please fix it, it's very annoying.
When I start foobar2000 everything is ok.
But after I minimize and maximize foobar2000's window it looks like this:
I'm using sabertooth theme ( WB v7.19) and I have win7 x32.
Any solution?
If I use Aero window frames and not the theme's frames the problem is solved. But I don't want to use Aero...
I didn't have this problem in WB v7.1. Should I go back to v7.1 or you'll release an update soon?
1,844 views 4 replies
Nice support..
Another program (digsby):
WB 7.19 is a beta so you may be better off reverting to WB 7.1 if you are experiencing problems which cause major problems for you.
We will look into resolving the issue with those minimized windows in the next WB beta update.
Thanks for the update. It's fixed now.
