ironclad,be responsible and help me since ive waited for help for dang near six months now.
particle forge wont work,checking the event logs it says this:
- System
- Provider
      [ Name] Windows Error Reporting
- EventID 1001
      [ Qualifiers] 0
  Level 4
  Task 0
  Keywords 0x80000000000000
- TimeCreated
      [ SystemTime] 2010-10-12T21:34:09.000000000Z
  EventRecordID 7105
  Channel Application
  Computer corbo-laptop
  Security
- EventData
      0
    CLR20r3
    Not available
    0
    particleforge.exe
    1.0.3345.32477
    49a89b3b
    System.Xml
    2.0.0.0
    4a275e0f
    2818
    123
    System.InvalidOperationException
    C:\Users\corbin\AppData\Local\Temp\WER589A.tmp.WERInternalMetadata.xml
    C:\Users\corbin\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_particleforge.ex_d366c4a98b9bbf1be8b1ce958787e4e96311dd84_0e6f6151
    0
    70f86d26-d648-11df-9645-00219be69fc4
    1
:Version=1
EventType=CLR20r3
EventTime=129313928475732663
ReportType=2
Consent=1
UploadTime=129313928476372699
ReportIdentifier=70f86d26-d648-11df-9645-00219be69fc4
WOW64=1
Response.type=4
Sig[0].Name=Problem Signature 01
Sig[0].Value=particleforge.exe
Sig[1].Name=Problem Signature 02
Sig[1].Value=1.0.3345.32477
Sig[2].Name=Problem Signature 03
Sig[2].Value=49a89b3b
Sig[3].Name=Problem Signature 04
Sig[3].Value=System.Xml
Sig[4].Name=Problem Signature 05
Sig[4].Value=2.0.0.0
Sig[5].Name=Problem Signature 06
Sig[5].Value=4a275e0f
Sig[6].Name=Problem Signature 07
Sig[6].Value=2818
Sig[7].Name=Problem Signature 08
Sig[7].Value=123
Sig[8].Name=Problem Signature 09
Sig[8].Value=System.InvalidOperationException
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7600.2.0.0.256.48
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
UI[2]=C:\Users\corbin\Desktop\ParticleForge3\ParticleForge 3\ParticleForge.exe
UI[3]=ParticleForge.exe has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution and close the program
UI[6]=Check online for a solution later and close the program
UI[7]=Close the program
LoadedModule[0]=C:\Users\corbin\Desktop\ParticleForge3\ParticleForge 3\ParticleForge.exe
LoadedModule[1]=C:\Windows\SysWOW64\ntdll.dll
LoadedModule[2]=C:\Windows\SYSTEM32\MSCOREE.DLL
LoadedModule[3]=C:\Windows\syswow64\KERNEL32.dll
LoadedModule[4]=C:\Windows\syswow64\KERNELBASE.dll
LoadedModule[5]=C:\Windows\syswow64\ADVAPI32.dll
LoadedModule[6]=C:\Windows\syswow64\msvcrt.dll
LoadedModule[7]=C:\Windows\SysWOW64\sechost.dll
LoadedModule[8]=C:\Windows\syswow64\RPCRT4.dll
LoadedModule[9]=C:\Windows\syswow64\SspiCli.dll
LoadedModule[10]=C:\Windows\syswow64\CRYPTBASE.dll
LoadedModule[11]=C:\Windows\syswow64\SHLWAPI.dll
LoadedModule[12]=C:\Windows\syswow64\GDI32.dll
LoadedModule[13]=C:\Windows\syswow64\USER32.dll
LoadedModule[14]=C:\Windows\syswow64\LPK.dll
LoadedModule[15]=C:\Windows\syswow64\USP10.dll
LoadedModule[16]=C:\Windows\system32\IMM32.DLL
LoadedModule[17]=C:\Windows\syswow64\MSCTF.dll
LoadedModule[18]=C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
LoadedModule[19]=C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_d08a205e442db5b5\MSVCR80.dll
LoadedModule[20]=C:\Windows\syswow64\shell32.dll
LoadedModule[21]=C:\Windows\syswow64\ole32.dll
LoadedModule[22]=C:\Windows\system32\profapi.dll
LoadedModule[23]=C:\Windows\assembly\NativeImages_v2.0.50727_32\mscorlib\f58ab951b57c8526430486dcf7ee38fd\mscorlib.ni.dll
LoadedModule[24]=C:\Windows\system32\uxtheme.dll
LoadedModule[25]=C:\Windows\assembly\NativeImages_v2.0.50727_32\System\500ddd904b1099f95552a81b54223b7f\System.ni.dll
LoadedModule[26]=C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Drawing\fdeec42fa02f3d789c42be2e33b130eb\System.Drawing.ni.dll
LoadedModule[27]=C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\f92c882fd4e7005c005e208daa04c28d\System.Windows.Forms.ni.dll
LoadedModule[28]=C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorjit.dll
LoadedModule[29]=C:\Windows\system32\CRYPTSP.dll
LoadedModule[30]=C:\Windows\system32\rsaenh.dll
LoadedModule[31]=C:\Windows\system32\RpcRtRemote.dll
LoadedModule[32]=C:\Users\corbin\Desktop\ParticleForge3\ParticleForge 3\ManagedIron.dll
LoadedModule[33]=C:\Windows\syswow64\OLEAUT32.dll
LoadedModule[34]=C:\Windows\system32\WINMM.dll
LoadedModule[35]=C:\Windows\system32\d3d9.dll
LoadedModule[36]=C:\Windows\system32\VERSION.dll
LoadedModule[37]=C:\Windows\system32\d3d8thk.dll
LoadedModule[38]=C:\Windows\system32\dwmapi.dll
LoadedModule[39]=C:\Windows\system32\DINPUT8.dll
LoadedModule[40]=C:\Windows\system32\d3dx9_36.dll
LoadedModule[41]=C:\Windows\system32\XINPUT1_3.dll
LoadedModule[42]=C:\Windows\syswow64\SETUPAPI.dll
LoadedModule[43]=C:\Windows\syswow64\CFGMGR32.dll
LoadedModule[44]=C:\Windows\syswow64\DEVOBJ.dll
LoadedModule[45]=C:\Windows\system32\WSOCK32.dll
LoadedModule[46]=C:\Windows\syswow64\WS2_32.dll
LoadedModule[47]=C:\Windows\syswow64\NSI.dll
LoadedModule[48]=C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_d08a205e442db5b5\MSVCP80.dll
LoadedModule[49]=C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_d08a205e442db5b5\msvcm80.dll
LoadedModule[50]=C:\Users\corbin\Desktop\ParticleForge3\ParticleForge 3\ForgeLibrary.dll
LoadedModule[51]=C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.16385_none_72fc7cbf861225ca\gdiplus.dll
LoadedModule[52]=C:\Windows\system32\WindowsCodecs.dll
LoadedModule[53]=C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Xml\3060dfcdecbeb8ee65077fb29b217c3d\System.Xml.ni.dll
LoadedModule[54]=C:\Windows\system32\shfolder.dll
LoadedModule[55]=C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Configuration\4be2653d1c9804d2ff6e6b66d22764e1\System.Configuration.ni.dll
LoadedModule[56]=C:\Windows\system32\apphelp.dll
FriendlyEventName=Stopped working
ConsentKey=CLR20r3
AppName=ParticleForge.exe
AppPath=C:\Users\corbin\Desktop\ParticleForge3\ParticleForge 3\ParticleForge.exe
ReportDescription=Stopped working
it does this and i have tried EVERYTHING,net. framework 2.0.0 and ive tried 3.5.1 and 4.0 and ive ran it from the sins directory and entrench directory and still says particleforge .exe has stopped working then closes
ive also unistalled sins and partcleforge and re-installed sins and re-downloaded particleforge.
so pls help,someone
5,128 views 7 replies
also i emailed ironclad T-W-I-C-E and they sent me what probably was an automatic responce that did NOTHING
AAARRRGGGGHHHHH
I can fix your problem
I will upload my ENTIRE FORGE.
Expect it soon.
If this does not work, get .NET updates, as Particle Forge uses .NET.
Oops, I can't seem to be able to upload 2 Gb.
I will upload a tiny forge instead...
Add your TextureAnimation Directory, your Texture Directory, and your mesh directory into the main folder.
See if this works.
2GB????!?!??!
