DesktopX 2 help/problem
Occasionally, Desktop X will crash on me and unload. If I try to reload a theme, it get a warning that pops up and says DesktopX.exe - No disk
device/harddisk2/dx
It give me Try Again/Cancel/Continue, but no matter which button I press, the warning continues to pop up. I end up having to turn my power off. There's no way out of it, it won't let me close it, not even with Alt-F4 or the Task Manager, nor can I shut down with the task manager.
Any ideas?
Powered by SkinBrowser!
1,614 views 2 replies
You probably have 2 instances of it running...check Task Manager.
Are you running Rainmeter? I found that if I quit this app, it worked fine. Its a right bugger to quit though, you need persistence!
Also, anyone else having problems with IconX? I find that if the icons are shown then the Desktop X menu doesnt work and the normal windows menu is on. Any suggestions?
