Windowblinds7 vs. 6 problems & system tray problem
Hiya,
I'll just post exactly what happened so you can have a better way to understand what I'm trying to say lol.
I got email on new theme for my colors so I loaded up Impulse to download and install it.  I then opened Mycolors and chose the new Music theme which is very nice tyvm.  I usually choose alternate colors with Windowblinds because I love purple :P  So I already had purple chosen as my color.  When I loaded up the Music theme it was in a pinkish color because it still had the settings from Windowblinds.  I opened windowblinds7 and tried to choose NONE in the color choices for the theme.  It would not change the color to the default for the Music theme.  I then opened Windowblinds7 (I think) via the Impulse window and this opened the 'old' setup instead of the new GUI of the beta.  In there the color setting was still checked.
I think I have some conflict between these 2 GUI setups or something.  I am trying "not" to choose the new GUI setup in the beta since this latest update if I don't have to, only because there are so many color change problems (desktop color has no settings at all in the new GUI yet).  Anyways when I click the shortcut on my desktop it opens the 'new' GUI setup, when I open it via Impulse it opens the 'old' GUI setup yet (does this each time an update happens and usually I choose the new setup, but don't want to this time).
Anyways, I had to open the old setup to fix this issue which is saying the new setup doesn't uncheck the things set in the old setup?  Does that even make sense? hehe I hope so cuz I am not sure how else to explain it.  Either way I fixed it via the old setup by unchecking the coloring options in there so now it's at the default colors for the skin like it should be.
Also there is still a system tray problem with the icons not showing up in many of the skins.  I can go through the skins I have installed and list them if you like, or if you need me to do something else for this just let me know that too, thanks.
6,230 views 5 replies
Is this issue ever going to be addressed and I wonder if I'll ever get an answer even?  Guess a ticket is the only way to get anyone to read this stuff or answer you :/  3 updates so far since this happened and it's still not fixed. :/
what OS?
With WindowBlinds 7, the use of the old UI is unsupported.  Please use the new UI.
The next update will remove the old UI.
LOL well you didn't read that very close I don't think as this issue spans both versions.  And you never even answered the actual question, sooooooo Can I get time frame when this actual icon issue is going to be resolved??  I sure hope you guys plan to add all the color options before you take away the only version setup that gives them to us :/
Windowblinds 7 is in BETA....if the BETA process is causing you issues, Id' suggest rolling back to version 6.
