Blank click areas.. Problem
I am having nothing but problems with ObjectDock concerning the following.
When I open other applications whether it be Adobe Illustrator/Photoshop or anything else.. I find that thare are screen areas that I cannot click my mouse in.  Call them blank sports.. They are always down near the bottom of my screen but not right on top of where my Object Dock is ( if you were to remove the application covering the desktop ).
The only way I can get rid of the blank spots is to shut down Object Dock. Then these areas return to normal and I have no mouse issues..
I am using Vista 64 bit.
I would list what other programs I have going but that would take a while..
First off, has anyone else run into this problem ?  If so, can you point me in the right direction ?
Thank you...
1,970 views 6 replies
Open OD config and go to  "Positioning".At the bottom make sure you don't have Reserve edge of screen checked.
odd. it stopped doing it.. I did not have that clicked but will monitor.. if it acts up again, I post what might be causing the problem.
David...
Still doing it.. Here is a pic.  Inside the red is the blank - non click area.. I usually have the dock underneath but brought it forward to show it's position in relation to the blank spot.
Blank Spot
David...
I hadn't heard of that before...
Yes, it is very strange... I call it the hole of death.. I might have to just stop using objectdock as a result..
David...
you using the free or plus version?
if plus, do you have hotspots enabled?
