Need help with finding LUA info
I've been searching for about an hour, and I cannot find the values for how much xp you need for each level. Anyone know where this is? Any helpful answer will result in thanks and karma. :)
19,412 views 5 replies
Inside game.lua
DefaultHeroExp = {
        {Amount = 0       },#1
        {Amount = 200     },#2
        {Amount = 500     },#3
        {Amount = 900     },#4
        {Amount = 1400    },#5
        {Amount = 2150    },#6
        {Amount = 3025    },#7
        {Amount = 4025    },#8
        {Amount = 5150    },#9
        {Amount = 6400    },#10
        {Amount = 7775    },#11
        {Amount = 9275    },#12
        {Amount = 10900   },#13
        {Amount = 12650   },#14
        {Amount = 14525   },#15
        {Amount = 16525   },#16
        {Amount = 18650   },#17
        {Amount = 20900   },#18
        {Amount = 23275   },#19
        {Amount = 25775   },#20
        #{Amount = 28750  },#21
        #{Amount = 31500  },#22
        #{Amount = 34375  },#23
        #{Amount = 37375  },#24
        #{Amount = 40500  },#25
plans for lvl 25?!
plans for lvl 25?!
There is (was) a debug command that makes your demigod level 25.
Back in beta, your demigod was able to lvl up till 25.
Thanks, gunblob! Karma given.
