Need Help Packaging Sound Themes
I bought the Sound Packager because I was under the impression I would be able to use it to package my sound themes then upload them to the site.  I can't find any help on how to do this.  I can't even find my sound theme I made in the Windows XP sound program.  I've searched and searched both online and throughout my system and all I can find is the system default sound files are located in Windows/Media but my theme file sounds are not there.  When I try to use the Sound Packager, it says my theme already exists but I can't find it in the My Documents/Stardock/Sound Packager folder.
I need to know the path to where I can find the sound theme I originally made so I can put it somewhere that I can find it easily.  Anyone know the path?  I was in the Sound program from the Control Panel, and I did a Save As.  I can see a few of the Sound Packager themes I had downloaded but not all of them.  And of course my theme shows up there but I can’t access the folder it must be stored in, I need to know where the folder is located, please!
BTW, I don't have the path C:\Documents and Settings\Owner\Application Data\Stardock\SoundPackager\Packages.  I don't have Application Data, I do have the Stardock/SoundPackager/Packages folder but my theme is not in there.  Which is why I'm really confused as to why it tells me my theme already exists when I try to use New Package.
4,131 views 0 replies
