3Ds Max problem when using WindowBlinds
help please?
okay, i got my 3Ds max program today, i was very exciting untill i installed it... for some reason i have to unload WindowsBlinds each time i want to use my new program (3Ds Max) otherwise it will shut down when ever i press something e.g just minimizing the bloody window fucks it up.
I'd like to see someone come up with a solution, if they can! seems a bit tad unusual though:( if there's anything you can tell me please do:) i really dont want problems using this:(
thanks.
8,328 views 4 replies
You need to exlude it from being skinned in WBconfig, I don't think they play well together, I know C4d doesnt.
thank you man! i thought so cause the display gets all fucked around the edited area's! anyways i'll go see if i can stop it from beeing skiinned now... i'll be back "says rob with a manly strong voice"
oh no, there's no option to exclude any program from beeing skinned... where abouts is the settings for this? i clicked on the WB icon then whent to setting but there's no option.
ahhh never mind i found it:) i had to add it as an app!
and it works now just dont get the option to close or minimize it! well ii do if i right click the window, but the buttons on the top right corner have gone:P meh well! it works and im happy! thank you so much for the help:)
