HELP! Problem with installing Impulse.
Ok, so I downloaded the setup program but, when it says, 'setup will now install impulse to your computer', I click next and it says there is a problem with my connection/firewall settings. There is no problem with my connection as I can still navigate the web and whatnot and, I even tried it with my firewall turned off and still get the same error message.
Has anyone else had this problem and, what did you do to correct it?
755 views 1 replies
Try: http://www.impulsedriven.com/impulse_setup_full.exe
There were some server issues a little while ago that were causing the "regular" Impulse setup to fail since it had to download additional files. The full setup has everything locally so it doesn't try to download anything.
