[Cause and solution found] OD Plus startup problem
When my system starts I get the Object Dock main window opening instead of just the docks themselves loading.
From what I can work out there is a Startup entry in both the Startup (User) section of the registry and in the Startup (Common) section.  However if I remove either of those they both vanish.
This also happens with RightClick.
Anyone got any idea how to solve this minor annoyance?
3,221 views 3 replies
If you haven't done so already, please contact support@stardock.com and start a trouble ticket.
OK, will do, thanks.
Actually - no need, I have found the cause.
Whilst checking my system settings before emailing support I spotted that there was a stray "desktop.ini" file in the "All Users / Programs / Startup" start menu folder. No idea how it got there but removing it sorted the problem.
Thanks anyway.
