Compatibility problem between Bootskin and Logon Studio
Hi,
Having to reinstall my XP I noticed a compatibility problem between Bootskin and Logon Studio : :(
Bootskin boot screens works  fine until I install Logon Studio causing BSOD. The only way I found to solve this is to uninstall bootskin as I "use" more logon screen than boot screen  ;)
Of course I tried with the other bootskin versions.
10,314 views 5 replies
Hmmm . .very odd.  Never heard of this before.  (:(
Actually yes there does seem to be a problem with this, but in a different way. The bootskin and the LogonStudio are installed ATM on this computer. However, when using the LogonStudio in conjunction with the Bootskin, I will get something along the lines of where the Bootskin (any one of them) will show up... ok so far so good...
Now here's the problem... after the bootskin stops and tries to go into windows... well it just stops. There won't be anything but a black screen and then the computer will shut down after a few minutes.
I went back and reset the bootskin to default and sure enough the computer now works fine with the logon screen I selected.
Now when I reverse it and use the default logon and another bootskin, it works. No clue why, but it just does.
Now here's the problem... after the bootskin stops and tries to go into windows well it just stops. There won't be anything but a black screen and then the computer will shut down after a few minutes. I went back and reset the bootskin to default and sure enough the computer now works fine with the logon screen I selected. Now when I reverse it and use the default logon and another bootskin, it works. No clue why, but it just does.
***spam removed***
Bootskin on XP is unstable and unsupported. I don't recommend using it.
In Bootskin XP to work correctly, there is one feature!
 1.Try before you install the new skin, install the first Windows boot screen by default! (*No restart
2. Then install the new skin, (*usually the problems are removed
