problem with windowblinds...HELP!!!
When i try to apply changes to my computer it only goes to windows classic view not the one i want
WindowBlinds version : WindowBlinds 5 (5.5 (build 92 x86))
(Plug and Play Monitor) 1 is attached to RADEON 9200 PRO Family (Microsoft Corporation)
Wblind.dll 2007/02/21 15:06:20
Wbsrv.dll 2007/02/07 17:31:19
Wbconfig.exe 2007/02/21 15:06:33
Wbload.exe 2006/09/30 13:59:14
Wbhelp.dll 2004/09/18 15:37:07
Wbui.dll 2005/12/06 21:29:06
Tray.dll 2006/04/28 18:27:49
1,846 views 3 replies
Where did you obtain this copy of WindowBlinds? You should have better results if you remove this copy, reboot and install either the 'trial' version or purchase the full version at - Windowblinds
How long have you been using WindowBlinds? Is this the 60 day free trial version? I think you may need to consider purchasing WindowBlinds. You can find it here. If you do decide to purchase it, remember to backup your themes, deinstall the bad version you have, reboot and then reinstall your purchase.
Hankers you beat me. Drat.
This =
indicates it's supposed to be a paid version
My 5.5 (build 92 x86) via SDC:
Wblind.dll 2007/02/21 D&T match
Wbsrv.dll 2007/02/07 D&T match
Wbconfig.exe 2007/02/15
Wbload.exe 2006/03/13
Wbhelp.dll 2004/09/18 D&T match
Wbui.dll 2005/12/06 D&T match
Tray.dll 2006/04/28
if this was a standalone go here: https://www.stardock.com/support/ and enter the email you purchased with - you'll get a link to the latest released version you're allowed
on the other hand if it's not purchased - uninstall, reboot, and purchase it if you like it
these:
do match these:
another cracked:
(Plug and Play Monitor) 1 is attached to Radeon X1550 Series
Wbsrv.dll 2007/03/15 19:56:13
