Problems with Shell and Text-Color
Hi there!
I am currently working on a skin and run into the following problem:
I am trying to do a new shell-style and have the problem of how to set the following font-color:
Could anybody help me please
Cheers, mooq!
2,601 views 2 replies
mooq,
That color is hard coded on XP and the only way to change it is adding
custom .UIFile to the skin, they are custom XML-like files that control
the task panels but they are a bit complicated to deal since you have to
manually edit the code by hand.
This skin use these custom files: https://www.wincustomize.com/skins.aspx?skinid=5705&libid=1
inside the skin folder you'll se file with the extension .UIFile open 'em with
Notepad or other text editor to check.
try google for "UIFile tutorial" too, I remember there's one somewhere.
WWW Link
good luck.
