Problem starting application from dock
while working normally when started from desktop icons
hi i am using the object dock 1.90 built 536 free version on a fresh install of windows vista.
the dock is behaving strangly when starting application, few will start file while others will either not open or couase problems. for example its impossible for me to start zend development enviroment from the dock, the pgrogram loading screen appears but then it closes, while loading it from a desktop icon start fine. someting similar goes with servant salamander as well, from desktop it starts fine while from the dock it says that its running in compatibility mode. any guesses why the dock is behaving this way? and eariler version of the dock in vista did not cause my any problems.
any help from anyone will be apreciated. thanks
1,517 views 3 replies
I have installed the version i had on my previous vista setup which is version 1.5 built 527 and now it works perfectly fine.
anyone from stardock to confirm this is a bug???
oh well, i figured out the problem. probably object dock was installed in compatibility mode so all the aplications it tried to start inherited this compatibility mode and caused them problems. oh well, at least it did not take too long to figure this out.
Thanks for posting your fix.
