Right click help in ie7
help!!!
in my ie7 when i apply msstyles the right click is perfect but with wb its all mest up !!!
but why?
when you right click it goes like this:
________________
| cut|
| cop| but why???
| pas|
| sel|
| pri|
| pri|
|________________|
6,081 views 18 replies
which build?
see if anything here helps
build 5.0
its so annoying cuz i cnt read half the writin lol
build 5.0?
in February it was v1.20 Build 739
oh, you meant WB, yes?
I get the same problem. I have the lastest build of WB trial. I'm messing with it now to see if I wish to buy it. I noticed a problem with ALL skins. When right clicking on a page in ie7. the popup menu does not display correctly. It looks like the popup menu is a little wider than normal, and the text is aligned too far to the right where only the first four or five letters are visible.
so far everything else looks ok.
Is there a way to fix this?
yes wb 5.0
do you now ay fix for this
and
open WB configuration, click view my system info on the left, copy/paste to here all the info
I am having issues with WB and the right-click menu in IE7 only. The right-click menus seem to be fine everywhere else other than IE7. Here is how mine looks like in IE7:
At first I thought it was a skin issue, but seems to happen with all skins. Here is the system information from my WB:
WindowBlinds version : WindowBlinds 5 (5.5 (build 92 x86))
(ViewSonic VA1912w SERIES) 1 is attached to NVIDIA GeForce 7900 GTX
Wblind.dll 2007/02/21 15:06:20
Wbsrv.dll 2007/06/15 14:44:13
Wbconfig.exe 2007/02/21 15:06:33
Wbload.exe 2006/09/30 13:59:14
Wbhelp.dll 2004/09/18 15:37:07
Wbui.dll 2005/12/06 21:29:06
Tray.dll 2006/04/28 18:27:49
This shows full purchased version, try updating thru Stardock Central. Current WB version is WindowBlinds 5 (5.51 (build 97 x86)). Did you have the trial version installed before full, if yes did you unistall it before installing new. You have some dates on files that are newer than mine, which is the latest version.
I have exact same problem.
Your computer has a Windows Experience Index base score of 1
Your Windows Graphics Experience score is 1.9
WindowBlinds version : WindowBlinds 5 (5.51 (build 110 x86 - Vista Edition)) - Shareware
(Generic PnP Monitor) 1 is attached to Intel(R) 82852/82855 GM/GME Graphics Controller (Microsoft Corporation - XDDM)
Wblind.dll 2007/06/18 15:55:34
Wbsrv.dll 2007/03/07 11:08:27
Wbconfig.exe 2007/06/19 11:43:09
Wbload.exe 2006/03/13 16:54:14
Wbhelp.dll 2004/09/18 16:37:07
Tray.dll 2006/04/28 19:27:49
Wbload.dll 2007/05/26 12:35:56
Happens no matter what skin I use and only in IE7.
Can anyone help.
hey guys...ŽŽŽ
i'm Ž newbie at thiŽ stuffŽŽ.. i just installed WB trial just yesterday and like it very mŽch ŽŽŽ I had the same problem as you guys.
ŽŽIn IE7 when I right-click all the options ŽŽŽŽ are shifted to the right and Ž couldn't read it.. technically i knew what everything was... but i'm a perfectionist.ŽŽŽ i've tried every skin to see if itŽŽ is the particular one IŽŽ was using. after all the trial and error i SOLVED it.ŽŽŽŽŽŽŽŽ
mostŽŽŽ likely ŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽ, ŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽand ŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽŽ.
hopeŽŽŽ ŽŽŽŽŽŽ fixesŽŽŽŽŽŽŽŽ ŽŽŽ...ŽŽŽŽŽ
ŽŽ
ŽŽŽŽŽŽv
Here's what I found out, the problem doesn't occur in two skins, "A Dreamy World" and "Impulse", I'm not sure why, but I hope this helps anyone who is trying to figure it out... it may be in the the code for these skins, but I'm not sure as I'm a newbie
Okay, I've actually figured out the problem. Windows blinds has a problem displaying icons in menus that aren't flat. The only way that I have found to fix it is to use skin studio to make the menus flat.
here is an example of what I'm talking about
this is an example of a flat menu. The non-flat menus are the ones that use a custom image i.e. one with rounded corners
Hi.
I have the same anoying problem. Someone in Stardock has to no what cause that? Or at least try to find it out, dont you think?
stipau
Hi
I found out what cause the problem for me.It is BitComet in the Context Menu that coming up when i right click in explorer.
I just Started BitComet, and clicked on options, and klicked off ; Add BitComet Download Command to IE Context Menu. Now there is no problem anymore.I see that one of you have Google that seems to make the same problem. I dont know how to remove it from the Context Menu, but im sure it is a way to solve that to.
stipau
