Help for Visually Disabled novice’s first project!
Vista GUI in XP
I use XP accessibility settings BLACK HIGH CONTRAST due to poor vision. I had the pleasure of recently uploading the XP Vista AeroGlass skin which I like very much but, you guest it I can't affect a AeroGlass setting with the accessabilty BLACK HIGH CONTRAST enabled. Two questions.
1. Is it possibly to apply the BLACK BACKGROUND & WHITE TEXT in the Vista AeroGlass feature set [icons ,folders, etc] by reversing each colour option & each tiny detail manually the WindowBlinds or will I be able to apply the effect with one option I don't know about?
2. Will Vista ship with an accessibility AeroGlass option?
I'll be grateful if someone would help be create such a skin for myself and other visually disabled users. :Happy
775 views 0 replies
