Logon Studio engine will not export
My Logon Studio engine flipped out on me. Since I started
with Wincustomize, I easily and simply pressed the 'Export Button' and voila
the .logonXP file was added to my logon files. Now, when I press the 'Export Button',
the 'successful download message' comes on instantly, where before it was a two to
three second window. Consequently, the 'successful' message is false, as I have no
.logonXP file for said creation showing anywhere.
I've redownloaded 5 times from Stardock's 1.8 to download.com's 1.0 to no avail. Thus, I am unable to continue with new Wincustomize logon sharing.
Any simple answers to this dilemma?
1,899 views 2 replies
Yes there is!
Edit the Logon file using the UIFile. This will allow you to still produce and share with the community. After doing this, DO NOT open the edited logon file with the LogonStudio Editor. It will change all your editing.
.logonXP files are just renamed .zip's...so just Zip your folder from the logonstudio directory, then rename it to a .logonxp file to upload.
using 1.0.64 works for me
