Speed Ability VS. Map Movement Speed
What is the difference between
< SpeedAbility > located in the Tech tree under Impulse Drive and Warp Drive
and
< Speed > located on the Ship Components?
I know the < Speed > relates to how far you can move, and I think that the < SpeedAbility > tag is for combat speed, but does it make any difference? Any at all? Or is it one of those tags that originally had a purpose but is no longer used because of a problem with how AI used it?
3,782 views 3 replies
< Speed > raises the speed of any ship which has that module.
< SpeedAbility > raises the base speed of all your ships. For instance, once you get Impulse Drive, a ship without engines will now move 2 spaces in a turn instead of just 1.
Speed on engines gives X amount of speed to the ship you place the engine on. SpeedAbility on a tech gives a speed bonus to ALL ships once you've researched that tech, without needing to add any parts to them.
Speed has absolutely no effect in combat, and never has.
Thanks for clearing up my misunderstanding guys
