Okay, I should have said reversing parts, Kryo?
What I meant was can you reverse a part? I know about "mirroring" but there are a few pieces that could work as wings, but only on one side. If you use it for the other side the angles are wrong, not the hardpoints, the angles. Probably nothing to do about it but I don't understand why the part is in there if you can't reverse it. What good is one wing? Maybe I'm missing something. Any help?
3,000 views 5 replies
Yeah, that's what bugs me most. Some parts are either nonsymetrical, or have their centerpoint a bit off. See Hyperwarp I for example, it's totally off.
Yeah, been hoping Kryo would read this and respond. Probably nothing that can be done about it, maybe short of using his hull mod, which I don't even think that allows what I'm looking for. I'm sure you know the "wing" that I'm talking about, probably tenth down on the list or so, right Regicide? Nothing I try makes it work when trying to put it on both sides to make wings.
Yeah, it irks me so. There are a few others that badly centered, like the giant slightly curved engine-thing, part of the constructor. You know the one, right? And the normal engine-style one(block on a stick) has badly oriented points... They're really minor issues, but they really bother me.
No. See the other thread for more.
