Help with Right Click Error!
Hi! I keep trying to right click in the object dock background and an error message pops up that says
ObjectDock.exe - Unable to Locate Component
This application has failed to start because YzDocklet.dll was not found. Re-installing the application may fix this problem.
2,089 views 3 replies
Hello MasturJeff,
I have contacted technical support regarding your problem and they will be getting back with you shortly.
: I would assume this means that you have a docklet in your dock that is no longer available or recognized. Which version of ObjectDock are you running and could you package your dock and send it in to support @ stardock.com?
-Mike
[Stardock Support]
I got the problem fixed. It was a weather icon that was no longer working because it had no zip code.
