Sound problems after updating
Hiya-
I just updated my copy of GalCiv2 with the latest retail patch last night; after I rebooted and went to go play it, I noticed a great deal of 'skipping' (and in some cases, 'stuck/repeating') audio both during the intro monologue, and music during the game setup screens.
Has anybody else encountered this? Is there something I should tweak to fix it? I didn't have this issue prior to the update, so I believe it's something to do with that.
Thanks in advance!
4,724 views 10 replies
Could you paste the contents of your debug.err file?
I have experienced the same problem.
Mine has done that since 1.0. It is always during heavy hard drive/processor usage, as when encountered when beginning a game or loading a saved game. It usually clears up after a short time. It does not effect game play once it clears up, but until then things can be a little choppy. And once it clears up it usually does not happen again during that gaming session.
The debug.err files won't show anything relating to this, by the way. I have checked mine over pretty carefully looking for anything that might give a clue.
I have noticed choppy sound also. If a debug.err is required, i could probably find it. Also, shouldn't this post be in a bug notes folder?
You could try playing with your audio acceleration settings.  We updated to the latest version of the Miles Sound System with 1.2, so that's probably why you're having trouble now.
Well, as I said, I have been having the same thing occur since 1.0. In fact, it may not be quite as bad since you went to Miles.
Are there any optimizations you could suggest? I really do not want to turn down the acceleration settings, but sometimes little things like having a particular audio codec as #1 priority can make a difference.
Yep, the sound was fine until I installed the update patch. Now, the introduction glitches like a scratched cd.
Ok, I just lowered the sound card acceleration by one notch and it fixed the problem. It no longer skips or glitches.
I dug this up with search here on the forum, I dont see any resolution to it It drives me insane. It is like having a favorite band, but the only CD you have of them skips like no tomorrow, makes it unplayable.
I have made sure my SB Audigy is up to date and not Accelerated, didn't make any improvements.
Here is my debug and stuff:
Creative Diagnostics Test Log
Detected device:
Sound Blaster Audigy
Tested device:Sound Blaster Audigy
02/05/2007 09:33:15PM Drivers Tests Pass
02/05/2007 09:33:18PM Windows Multimedia Tests Pass
02/05/2007 09:33:19PM DirectSound Tests Pass
Debug Message: Version v1.4x last updated on: Mon Oct 23 17:43:56 2006
Debug Message: GalCiv2 is activated.
Debug Message: Checking DX Version.
Debug Message: *********DXDiag info follows.*********
System Info
Time: 2/5/2007, 21:32:11
DirectX Version: DirectX 9.0c (4.09.0000.0904)
Machine Name: NSA
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Languages: English (Regional Setting: English)
System Manufacturer: Compaq Presario 061
System Model: DK301A-ABA S4500NX NA210
BIOS: BIOS Date: 02/24/04 19:25:41 Ver: 08.00.08
Processor: AMD Athlon(tm) XP 3000+, MMX, 3DNow, ~2.2GHz
Physical Memory: 1536MB RAM
Page File: 192MB used, 2346MB available
Windows Dir: C:\WINDOWS
Display Info
Display device 1:
Device Name: \\.\DISPLAY1
Card Name: VisionTek RADEON X1300 (Omega 3.8.330)
Manufacturer: ATI Technologies Inc. (Omega 3.8.330)
Chip Type: Radeon X1300 Series AGP (0x7146)
DAC Type: Internal DAC(400MHz)
Key Device: Enum\PCI\VEN_1002&DEV_7146&SUBSYS_19101545&REV_00
Display Memory: 512.0 MB
Current Display Mode: 1280 x 1024 (32 bit) (75Hz)
Monitor Name: Plug and Play Monitor
Monitor Max Resolution: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6660
Driver Date: 12/16/2006 21:50:46
DirectX Acceleration Enabled: Yes
Sound info
Sound device 1:
Description: Sound Blaster Audigy
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0007&SUBSYS_100A1102&REV_00
Manufacturer ID: 1
Product ID: 100
Driver Name: P17.sys
Provider: CREATIVE
Driver Version: 5.12.0001.0512
Driver Date: 7/6/2005 19:14:30
Type: WDM
Other Drivers:
Acceleration Level: 1
Cap Flags: 0
Min/Max Sample Rate: 0, 0
Debug Message: *********END dxdiag info.*********
Debug Message: Entering WinMain
Debug Message: ******* Starting Game Shell *******
Debug Message: Going Fullscreen
Debug Message: Preparing to change display settings.
Debug Message: Using multilsample setting: D3DMULTISAMPLE_NONE
Debug Message: Game Resolution: 1280 x 1024
Debug Message: Running fullscreen.
Debug Message: HAL (hw vp): VisionTek RADEON X1300 (Omega 3.8.330)
Debug Message: D3DPRESENT_INTERVAL_DEFAULT
Debug Message: Refresh rate: 60
Debug Message: Bit Depth: 32 bit.
Debug Message: *********Checking D3DDevice Caps***********************
Debug Message: A full-color cursor is supported in hardware at high resolution modes.
Debug Message: RGB in format 6:6:6, Masks reported as ff0000:ff00:ff
Debug Message: Now Fullscreen
Debug Message: Shell initialization complete
Debug Message: ***** Initializing Game *****
Debug Message: Timer Frequency is 0 369e99
Debug Message: Initializing sound card.
Debug Message: initailizing bink
Debug Message: No string tables in C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default/Data/*.str
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Movies\*.bik
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Movies\techs\*.bik
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Gfx\*.png
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Gfx\Race\*.png
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\sfx\*.wav
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Music\*.mp3
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Event Music\*.mp3
Debug Message: Create setup screens.
Debug Message: Clear galaxy settings.
Debug Message: Clear influence.
Debug Message: Clear up laws.
Debug Message: Clear first time events.
Debug Message: Clear wonders and trade goods.
Debug Message: Clear sector mapper.
Debug Message: * Collectors Edition *
Debug Message: Set mouse.
Debug Message: Set update timer.
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\*.xml
Debug Message: Clear data definitions.
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\Techs\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\ShipComponents\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\ShipDefs\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Gfx\Planets\C0*.png
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\PlanetImprovements\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\TerrainColorSchemes\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\PlanetDescriptions\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\Anomalies\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\Events\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\UPIssues\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\Invasions\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\PoliticalParties\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\StarTypes\*.xml
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\StarbaseModules\*.xml
Debug Message: Reading Star Names
Debug Message: Reading Star Names... Done
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\CustomMaps\*.gc2map
Debug Message: No files found matching mask C:\Program Files\Stardock\TotalGaming\GalCiv2\Mods\Default\Data\Scenarios\*.gc2scenario
Debug Message: Creating Galaxy
Debug Message: Killing threads.
Debug Message: Kiling civs.
Debug Message: Killing ships.
Debug Message: Killing rallypoints.
Debug Message: Killing misc objects.
Debug Message: Killing stars.
Debug Message: Killing anomalies.
Debug Message: Killing space resources.
Debug Message: Killing colonies and planets.
Debug Message: killing scenario.
Debug Message: Clearing Turn Event Log
Debug Message: Galaxy Size Set: 18 x 18
Debug Message: Creating Random Map
Debug Message: Creating Random Map... Stars
Debug Message: Number of Unplaced Stars: 42.
Debug Message: Creating Random Map... Planets
Debug Message: *************** Failed To Place Planet ***************
Debug Message: Creating Random Map... Anomalies
Debug Message: Num Anomalies: 92
Debug Message: Creating Random Map... Resources
Debug Message: Creating Random Map... Done
Debug Message: TitleWnd: Quit Button.
Debug Message: Posting WM_CLOSE message.
Debug Message: WM_CLOSE message received.
Debug Message: GameUninitialize start
Debug Message: Killing hidden planet surface init thread. Waiting for it to die.
Debug Message: Aborting hidden planet surface initialization.
Debug Message: Hidden planet surface init thread dead.
Debug Message: Killing Galaxy
Debug Message: Killing Galaxy: Completed
Debug Message: Shutting down sound system.
Debug Message: Clearing sound and music handles.
Debug Message: GameUninitialize end
Debug Message: Device not cleared. 1 counts left.
Debug Message: D3D not cleared. 1 counts left.
Debug Message: Destroying Window.
Debug Message: Main Shell terminating normally
This is the first thing that I would look at. Also:
I use Audigy myself, and haven't had any problems, even with full acceleration. I am by no means an expert on these matters, but this should get you started until someone else comes along. Good luck.
