[help!]LogonStudio doesn't work well in my system
Hello,evryone!
I've used logonStudio just a few days.
But none of these .logonxp files I've downloaded works, even if the 3 default welcome login screens.
Whenever I applyed the welcome login screens , it return errror "value creation failed '' at line **" or something else. Then I'd have to press "enter" so many times to return login dialog box.
I'm using LogonStudio v1.0.64 in Windows XP SP2.
Please give some advices.Thank you very much!
1,083 views 8 replies
maybe a corrupt download / bad install = try uninstall it, reboot, download and install again
Hi,Bichur!
Thank you for help.
I am going to do what you say,then post my result .
God bless me !
I've heard that this problem due to my zhcon OS.
That's to say LogonStudio doesn't work well enough with windows XP zhcon(Chinese) .
Is that ture?
zhcon OS. is it mean chinese windows xp system,so am i ,but though ours os is chinese,is there no resolusino to sdjust this problem ,that seems to be terrible.i expext someone to do so .
please email [email protected] with system info and problem. The developers will be made aware and can address.
Very sorry that it is not working.
