system tray problem
lately, my desktopx themes have been having a problem with the system tray. the system trays in all of my themes are empty, but without it the system tray is there. any suggestions on how to fix this? sorry, i dont know too much about these things
11,122 views 4 replies
that I under stood...
this confused me:
what i meant was that when on the normal windows task bar, with no desktopx or anything, the tray icons would still be there.
i just added a system tray to my object dock though, and it works, so i dont have a problem anymore
You have to activate "Enable MCP notification area support" in Stardock Central->Settings->General and reboot.
If it still fails after Carl's advice, grab the MCP executable:
Stardock MCP download:
http://tinyurl.com/qa7kf
