Help: problem after installing Windowblinds
as above
when i installed windows blind, all default font was changed so it is italiciced. in the login screen, the "enter your password" text is shown as: "enter your password". it all comes out in italic. i know this is a small, insiginicant probelm, but its noe of theose things that annoys me. below is a piture of the problem.
as shown here: http://i16.photobucket.com/albums/b21/asoue202/grrrr.jpg
any help that could he me overcome this problem would be great.
thanks!
1,913 views 4 replies
the thumbnail is too small to see.
does this do it with all skins?
right click on the desktop > properties > appearance > advanced appearance (maybe)> pull down the drop down to 'icon', then look to see if the "I" on the bottom right is selected - if so, unselect it
yea. ive tried that, and i unistalled windows blinds, but for some reason, its not reverting back to UN-italics.
read a post before where someone had gone in and changed the default for the system from Tahoma and it screwed things up, but I can't find it....
if you find it, put it up. ive heard of ways to MANUALLY change all those settings... but i dun know how.
