Problem with display with WB;ODP and desktopx
I am having problem with my laptop display. I am running windowsblinds,objectdockplus and desktopx. when i leave the system unattended for 1 or 2 hours and when i come back i see a popup saying the message mentioned below and the screen is corrupt. i was not having this problem when i was using objectdockplus 1.20. i upgraded to 1.30 and the problem started. any help would be appreciated. I have the proper driver installed for the display.
Event Type: Error
Event Source: SiS315
Event Category: None
Event ID: 108
Date: 28-04-2006
Time: 21:09:47
User: N/A
Computer: ________
Description:
The driver SiSGRV for the display device \Device\Video0 got stuck in an infinite loop. This usually indicates a problem with the device itself or with the device driver programming the hardware incorrectly. Please check with your hardware device vendor for any driver updates.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 00 00 00 00 03 00 4e 00 ......N.
0008: 00 00 00 00 6c 00 04 c0 ....l..À
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
2,355 views 2 replies
Do you have a screensaver running?
That message will only appear in there is a bug in your driver (or HW failure - but driver is more common)
Yes i used to run a windows xp default screen saver. recently i have updaetd my system with autopatcher and while updating i added some screen saver comes with that neowin autopatcher. and when the problem occurs i hope the screen saver running was 3dwindowsxp. i have changed the screen saver now to default screen saver. i am using this display driver for the past 3 years and havent faced any problem. just suddenly the error popped up 2 or 3 times in the past 18 hours. while working before the system the error is not coming. only when leaving the system idle it happens. as ur telling the new screen saver may be having problem. let me check it. thank you for your suggestion.
