Reserve Edge does not work for bottom of screen
Running OD Free v1.90 build 536 on XP SP3, and love it. However, the option to "Reserve edge of screen" only works correctly if the position of the dock is top, left or right. If the position is bottom, the edge is not reserved.
If I have a window maximized and change the location of the dock to top, left or right, the window correctly adjusts itself to keep the edge reserved. If bottom, the maxed window overlaps the OD area. Any ideas?
